Date/Time: Wed, 22 Jan 2025 04:22:55 +0000
Custom Zoom
View Count: 904
[2018-09-03 11:10:05] |
User311951 - Posts: 31 |
Hi, I am aware of the bar spacing and vertical axis spacing options that allow users to zoom in and out of charts. However there are two views that I am interested in which are very zoomed in and very zoomed out (which takes a lot of manual effort to switch between i.e. dragging the x and y axis accordingly). I was wondering if there is a way to create a user defined amount of zoom which we can switch to at the click of button? This would be of great help. Thanks |
[2018-09-03 20:40:49] |
Really to accomplish this you need two separate charts and then you can change between them through the CW menu.
