Date/Time: Wed, 22 Jan 2025 04:30:35 +0000
[User Discussion] - Advice
View Count: 730
[2018-09-03 10:09:49]
AE16 - Posts: 31
Hi guys, looking into buying sierra charts however I have a few q's I hope someone can answer.
I trade spot FX with FXCM, what features do you get? Anything similar to DOM? Vol profile?
How does the software work across multiple screens?
[2018-09-03 20:47:52]
Yes Sierra Chart does have a trading ladder type of interface and it also has a Volume by Price study. Refer to:
https://www.sierrachart.com/index.php?page=doc/ChartTrading.html#ChartDOM
Volume By Price Study
Multiple screens are supported and full details are here:
Detaching and Attaching Chart Windows
[2018-09-04 09:40:56]
AE16 - Posts: 31
Ok thanks for the quick reply. Just to check this is for spot fx? I understand these are normal features for futures but how are they calculated for spot?
[2018-09-05 01:22:06]
Yes our answer is in regards to spot Forex.
This is explained more here:
Chart Data and Chart Data Files: Volume Data
