Date/Time: Sun, 24 Nov 2024 10:53:57 +0000
Setting ray and line to zero degrees
View Count: 1340
[2013-10-23 12:20:35]
BJV - Posts: 29
Is it possible to set a default degree of zero in global setting to draw a ray and line? Or any other way of doing it.
Thanks Brad
[2013-10-23 12:35:20]
If you press and hold the Control key on your keyboard when drawing a Line or Ray, it will be made vertical or horizontal depending upon which angle it is closest to.
