Date/Time: Wed, 22 Jan 2025 04:35:23 +0000
multiple charts on one tab
View Count: 1045
[2018-09-02 02:44:42] |
User828417 - Posts: 32 |
Is it possible, within 1 chartbook and within 1 tab, to have multiple charts of the same symbol on different time intervals so that I can display the multiple charts simultaneously on the screen? At the moment, when I duplicate a chart, I get a new tab.
[2018-09-03 07:38:25] |
No they will need to be separate charts in this case.
