Date/Time: Wed, 22 Jan 2025 04:25:00 +0000
Removing profiles...
View Count: 829
[2018-09-01 00:07:40] |
User629089 - Posts: 93 |
Hi, I have the TPO Profile Chart set up for both RTH and ETH and they're separated on the same chart. I'm wondering if you can remove a profile? For example now in ES, I've seen an educator that I follow removing the ETH profiles from below current prices leaving only the RTH profiles. But for current analysis he'll have both RTH and ETH profiles visible. He deleted the lower ETH profiles. Can something like this be done? Thanks... |
[2018-09-01 20:59:18] |
No, this is not supported. You can only prevent displaying the evening session profiles for prior days.
[2018-09-03 01:16:33] |
Hi, I'm a little confused. You can prevent displaying the eve session profiles for prior days? How would you do that? That's actually what I'm looking for. Thanks... |
[2018-09-03 06:51:08] |
This is controlled with this particular Study Input: Time Price Opportunity (TPO) Profile Charts: Exclude Evening Session Profiles Except For Last Day Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-09-03 06:51:20
