Date/Time: Wed, 22 Jan 2025 04:43:58 +0000
Time Zone
View Count: 776
[2018-08-31 12:01:36] |
User371906 - Posts: 141 |
Hi, I live in Poland and my broker is WHSelfInvest which has data feed via CQG. I can not get my chart (F.US.EPU18) have the same candlesticks (size, OHLC prices, etc) as CME chart. My PC is set Polish time (UTC +01:00) Can you please tel me what presets must be set: Data/Trade Service Settings / Time Zone ______? Chart Settings / Session Times / Start Time + End Time? Evening Session / Start + end Time? Chart Settings / Advanced Settings / Time Zone ____? Thank You Regards Date Time Of Last Edit: 2018-08-31 12:25:06
[2018-08-31 18:16:35] |
Set the Global Time Zone setting to New York: Time Zone Setting The chart itself should be set to use the global time zone. Follow these instructions here to apply the Global Symbol Settings to that particular chart: Global Symbol Settings: Update/Apply Symbol Settings to Charts Make sure you follow the optional step to enable the option to apply the Session Times so they will be automatically set for you. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-09-03 12:36:41] |
Good morning, I have followed these instructions including the optional one but it is still not placing correctly the candlesticks, 5, 15 minutes are good but 1, 2, 4 HRS not. Also read several other pages in web site but at time no go. The only symbol I trade is F.US.EPU18. Can you please look at (screen settings picture attached): Session Time (HH:MM:SS) Start Time 09:30:00 End Time: 16:14:59 Use Evening Evening 16:15:00 Evening End 09:29:59 New Bar At Session Start Thank You Regards |
Attachment Deleted. Chart Settings Session Time.JPG / V - Attached On 2018-09-03 12:24:50 UTC - Size: 184.18 KB - 217 views |
[2018-09-03 20:37:35] |
Well you will need to adjust the Session Times to what you require. We cannot know exactly what you will want or expect. Here is the relevant documentation: Chart Session Times Also specifically refer to: Chart Session Times: Bar Starting Times Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
