Date/Time: Mon, 25 Nov 2024 12:24:37 +0000
Mulitple Trading Accounts
View Count: 1425
[2013-10-22 20:37:24] |
User64020 - Posts: 3 |
Date Time Of Last Edit: 2013-10-22 22:25:58
[2013-10-22 21:04:36] |
Yes you can. Sierra Chart does support multiple trading accounts within a single copy of Sierra Chart. Each chart or Trade DOM can be set to use whatever trade account you have set it to. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-02-08 22:37:33] |
User33552 - Posts: 23 |
I have accts with 2 brokers.... Currently in "demo" mode with Sierra Charts. If I have installed Sierra Charts via broker that does not deal in ETF's (so ETFs do not show as a "symbol" choice). Do I need to install in a different way to get ETF feed from the broker that brokers ETFs? Asking because in "demo" mode from the "demo" broker the GLOBAL SETTINGS/DATA TRADE SERVICE SETTINGS does not offer any other broker. Thank you |
[2014-02-09 02:32:07] |
Do I need to install in a different way to get ETF feed from the broker that brokers ETFs? No. But we are not really clearly understanding this. The basic method is to configure Sierra Chart to work with a particular supported Data or Trading service according to the instructions linked from this page:https://www.sierrachart.com/index.php?l=doc/data.php#Services In your case, what you need to do is set up a standard installation of Sierra Chart: https://www.sierrachart.com/index.php?l=doc/doc_DirectAccount.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-02-09 02:32:28
[2014-02-09 18:44:57] |
For Clarification: Your documentation indicates that I can have multiple data feed sources. I need more than 1 because I have two brokers and one supplies limited information. I have 2 brokers...1 provides only futures quotes. The other broker provides ETF quotes. I am in demo mode with the broker that provides only futures quotes. In your choice in Global Settings, the Trade Service Settings does not show any other data feed source (ie, the other broker that supplies ETF quotes feed). When I go "live" with a real account, will the other broker with the ETF feed show as a choice of brokers? |
[2014-02-09 22:22:01] |
You need to use your own Sierra Chart account. You do already have that and this is what you have used to log into this Support Board with. Here are the complete instructions to use your own account and have a standard installation of Sierra Chart: https://www.sierrachart.com/index.php?l=doc/doc_DirectAccount.html You need to have installed two copies of Sierra Chart on your system. Each one configured for the particular service you want to use. Here are the instructions for that: https://www.sierrachart.com/index.php?l=doc/MultipleServices.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-02-09 22:22:48
