Date/Time: Wed, 22 Jan 2025 04:12:11 +0000
Renko Bars
View Count: 754
[2018-08-30 23:14:41]
User750920 - Posts: 280
I am looking to migrate from another charting program. Specifically IRT. I really like their renko bars though I do not know how they are configured. They only have one type and when you go to set it it says "Box Size [x reversal]" but only allows for one setting for the tick size.
Since I really like the way it displays when I use Renko in SC there is a difference and I have tried many different combinations and settings to no avail. Has anyone addressed this if they have come from IRT or are there any suggestions from support.
[2018-09-05 18:29:17]
You should be able to get a match by using Flex Renko which is documented here:
Renko Bar Charts: Flex Renko
