Date/Time: Sun, 24 Nov 2024 11:50:45 +0000
price bubbles
View Count: 1854
[2013-10-22 19:20:07] |
artfuls - Posts: 11 |
Is their a way to when a chart price or say the $tick reaches a new high or low for the day or sepcific time period it can display a price bubble at that high or low also can you make 1 chart candle sticks have different colors then all the others or is this just a global thing thanks |
[2013-10-25 15:40:13] |
support do you have any thoughts |
[2013-10-25 16:12:25] |
Sierra Chart - Max - Posts: 5730 |
You can use the Daily OHLC - Single Point study to get an indicator of when a new daily high or low are reached for a particular chart: http://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s239 To have custom candle colors for a particular chart, refer to the documentation here: http://www.sierrachart.com/index.php?l=doc/doc_GraphicsSettings.html To alter the color of a bar based on a custom alert condition, you can use the Color Bar Based on Alert Condition study: http://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s245 To add a study to a chart, refer to the documentation here: http://www.sierrachart.com/index.php?l=doc/doc_ChartStudies.html#AddingStudiestoaChart Sierra Chart Support Date Time Of Last Edit: 2013-10-25 16:32:36
[2013-10-25 16:19:32] |
Sawtooth - Posts: 4118 |
If you don't want the candle colors to follow the global setting, click on Chart >> Graphic Settings and uncheck Use Global... , then set the colors you want.
