Date/Time: Wed, 22 Jan 2025 00:38:17 +0000
Is there a counter for the current bar in a
View Count: 865
[2018-08-30 13:04:47] |
User297050 - Posts: 51 |
Is there a way to put on the chart the number of trades thus far that have occurred in the current open bar when you are using the "Number of Trades" charting option for your chart bars? Right now on my charts I can tell when the bar started but have no way of knowing if the bar is close to completion.
[2018-08-30 15:41:42] |
John - SC Support - Posts: 37369 |
Refer to the following study: Number of Trades If you want to display just the current bar data in the graph, then review the following Study Collection to get an idea of how to do this (you would need to change out the Average True Range study for the Number of Trades): https://www.sierrachart.com/AdditionalFiles/TextDisplayOfAverageTrueRange.StdyCollct For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-08-30 18:32:17] |
Another study you can use is the Countdown Timer study: Countdown Timer Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-08-30 18:32:25
