Date/Time: Wed, 22 Jan 2025 00:27:25 +0000
Buy and Sell Stops Disappear Overnight on Chart
View Count: 620
[2018-08-30 12:15:16] |
User56044 - Posts: 62 |
I'm using IB. My Buy and Sell Stop Lines disappear from my CL chart (and from the IB window) overnight although the initial Buy or Sell Line is still there. Is there any way to maintain my stops overnight? Must I reinstall them each day?
[2018-08-30 17:56:16] |
It sounds like you are referring to open Attached Orders. Make sure the Time in Force is Good Till Canceled for them: Attached Orders: Time In Force Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-08-30 17:56:42
