Date/Time: Wed, 22 Jan 2025 00:27:25 +0000
Lagging
View Count: 822
[2018-08-29 22:24:47]
GPST10 - Posts: 139
For couple of days or so I experience extreme lagging inside the SC. for example if I grab a timeline on a chart and move and release it takes about a 1 to 3 seconds for the move to show up - it is very frustrating especially when working to adjust some lines or studies to exact places were you need rapidly move cursor back and forth to fine tune.
Should I reinstall the SC?
I also checked Task Manager on side while doing this and no any number goes up like GPU MEM CPU - all of them are very low.
Please advise.
[2018-08-29 23:30:20]
Refer to help topic 30:
High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often
Our first recommendation is to go to Tools >> Manage Chart Drawings Window and reduce the number of chart drawings on the chart. There probably are too many of them.
[2018-08-29 23:59:27]
GPST10 - Posts: 139
I NAILED IT DOWN TO AUTO RETRACE STUDY SET FOR TOO MANY DAYS - I THINK I LEFT DEFAULT THERE BY ACCIDENT IT WAS 29 OR SO - NOW PUT 1 AND ALL LOOKS OK.
