Date/Time: Wed, 22 Jan 2025 00:31:08 +0000
TPO Subgraph
View Count: 822
[2018-08-29 22:08:46] |
User750920 - Posts: 280 |
In the TPO subgraph there are settings for OP, High, Low, Last and also Midpoint Marker, Initial Balance Range Color, Value Are extension lines. When I try to create Value or Name Labels for these items nothing populates- it does not work. But I am able to do so for the POC and the Singles. How can this be done for the others. |
[2018-08-30 14:26:11] |
John - SC Support - Posts: 37369 |
You can do labels for the items that have Extension lines, such as the Value Area and that is explained here: Time Price Opportunity (TPO) Profile Charts: Extension Line Labels The others do not support labels. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-08-30 15:05:56] |
It would be great if labels could be crated for the others too - just a friendly suggestion. Also can labels and/or lines be added to the VbP study on a regular bar chart for the IBH, IBL, MID, Open High, Low? |
[2018-08-30 18:01:42] |
Not sure what the relationship is between the Volume by Price study and IBH, IBL, MID, Open High, Low. But you can do these for the chart using the following studies: Initial Balance Daily OHLC Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-08-30 18:20:33] |
Not really a relationship - just wanting to have reference lines/labels on that type of chart and study so when I am looking at it I know where these references are regardless of the timeframe or bar type (1 minute 5 minutes, Renko etc.) of the bar chart.
[2018-08-30 18:38:19] |
Use the studies we linked to in our prior post above.
