Date/Time: Wed, 22 Jan 2025 04:11:20 +0000
Display Multiple Charts from 2 Chartbooks
View Count: 1904
[2018-08-29 19:33:13] |
User94606 - Posts: 327 |
Is there a way to display multiple charts from 2 different chartbooks across multiple monitors? I detached 4 charts from chartbook 1 and put them on monitor 1 but when I make chartbook 2(monitor 2) my active window, the detached charts in chartbook 1 (monitor 1) completely disappear.
[2018-08-29 21:04:58] |
You can set a chart window to always be visible. Refer to: Window, CB and CW Menus: Window Always Visible (Window) Also refer to: Detaching and Attaching Chart Windows: Detaching a Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-08-31 05:22:17] |
I tried making the chart always visible but the issue now is that the same chart is displayed twice. Any ideas on how to fix the charts being duplicated?
[2018-09-05 04:05:00] |
A chart can only display once. But it can be made always visible no matter what Chartbook is active. You may just want to not make a chart Always Visible and instead use multiple instances: Using DTC Server for Data and Trading in Another Sierra Chart Instance Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-09-05 04:05:27
