Date/Time: Wed, 22 Jan 2025 00:09:27 +0000
Order Error - DTC compatible service has indicated it does not support trading.
View Count: 586
[2018-08-29 16:39:02]
impert - Posts: 6
Trying to place orders on Sierra doesn't work with Transact i get the follow error:
TransAct Trading | You Are Connecting To A LIVE SERVER. All Orders Are LIVE ORDERS. | 2018-08-29 11:30:49 *
TransAct Trading | Connected To Transact Price Server. | 2018-08-29 11:30:52 *
TransAct Trading | Connected To Transact Order Server. | 2018-08-29 11:30:53 *
Order Error - DTC compatible service has indicated it does not support trading. Internal Order ID: 187503. Service Order ID: (none). Symbol: NQU8 | 2018-08-29 11:32:57 *
I have another installation of sierra on a separate computer and it works there, i copied global and symbol settings from that install to the other but it still didnt work.
I contacted Transact and they said it was on your end.
Trading simulation mode is off.
I have disconnected and reconnected several times throughout the day, always get the same error.
[2018-08-29 16:42:44]
We have activated Transact trading on your account.
Date Time Of Last Edit: 2018-08-29 16:42:52
