Date/Time: Fri, 31 Jan 2025 20:10:39 +0000
32 bit 64 bit
View Count: 1447
[2018-08-29 16:04:15]
User19467 - Posts: 5
sorry to bother you but I have tried my best to find out how to switch from my 64 bit over to 32 bit because I have some dll's written for 32 bit. I read somewhere written by Sierra that it is easy to switch back and forth....how do I do that please? Thank you
[2018-08-29 17:15:32]
Refer to the documentation about this here:
Software Download: Difference Between 32 and 64-bit Versions (Difference Between 32 and 64-bit Versions)
Date Time Of Last Edit: 2018-08-29 17:16:07
[2018-09-02 18:08:42]
opci - Posts: 90
i also have a problem with my personal dll study .. i have updated the new version of 1795 and my study does not read ... if i understand it well ... that's a problem because i need to run a 32 bit version in the folder?
[2018-09-03 06:33:06]
Yes you will need to use the 32-bit version of Sierra Chart if the custom study is built as 32-bit. Refer to:
How to Use an Advanced Custom Study or a Study Collection: Custom Study Not Listed or Not Displaying on Chart
Date Time Of Last Edit: 2018-09-03 06:33:31
[2018-09-03 21:10:39]
Xfanman1 - Posts: 320
If you have the original .cpp source code(or can get it from whoever wrote it for you if that wasn't you), you can also recompile it using the 64 bit version and your study will run in 64bit also.
Scott
[2019-05-29 17:18:51]
opci - Posts: 90
Xfanman1@ I can not even get in touch with the developer who made this dll ... do you have an idea to turn to that?
