Date/Time: Wed, 22 Jan 2025 00:03:51 +0000
Hidden control bars
View Count: 915
[2018-08-28 23:06:12]
User568537 - Posts: 21
Hi
I moved the SC folder from my desktop PC (two monitors) to my laptop but now the three floating control bars have vanished (however in Window>Control Bars the flags are still on Control Bar 1, 2 and 3)
How can I recover them? Thanks.
[2018-08-28 23:26:36]
User553714 - Posts: 184
Have you tried; windows >> reset windows? This is usually handy when windows go missing.
[2018-08-29 00:34:04]
You need to use this particular command:
Window, CB and CW Menus: Reset Windows (Window)
[2018-08-29 14:04:23]
The command did the trick. Thanks.
