Date/Time: Mon, 05 Oct 2026 07:22:15 +0000
Trial, individual scale and study setting for each instrument
View Count: 1031
[2018-08-28 18:38:43]
User149120 - Posts: 2
Hello!
How can I set individual scale constant range and Bid/Ask Minimum Volume Compare Threshold in Numbers Bars for each instrument?
For NQ Futures Constant Range 28, Bid/Ask Minimum Volume Compare Threshold 100.
For CL Futures Constant Range 1, Bid/Ask Minimum Volume Compare Threshold 300.
Thank you!
[2018-08-29 00:43:26]
There is not a way to do this for an individual symbol. They are set directly on the chart. And once they are set you can duplicate the chart. Refer to:
Using Chart Templates
Date Time Of Last Edit: 2018-08-29 00:43:42
[2018-09-12 12:36:12]
I've done code for individual scale constant range and horizontal line grid increment for each instrument.
#include "sierrachart.h"
SCDLLName("Custom Study DLL")
SCSFExport scsf_FunctionName(SCStudyInterfaceRef sc)
if (sc.SetDefaults)
    sc.GraphRegion = 0;
return;
  SCString mysym=sc.GetChartSymbol(4);
  SCString partsym=mysym.GetSubString(3, 5);
  sc.BaseGraphScaleRangeType = SCALE_CONSTRANGECENTER;
  if (partsym == "ENQ")
    sc.BaseGraphScaleConstRange = 28.0f;
    sc.BaseGraphHorizontalGridLineIncrement = 10.0f;
    return;
  if (partsym == "CLE")
    sc.BaseGraphScaleConstRange = 1.12f;
    sc.BaseGraphHorizontalGridLineIncrement = 0.5f;
    return;
  if (partsym == "YMU")
    sc.BaseGraphScaleConstRange = 112.0f;
    sc.BaseGraphHorizontalGridLineIncrement = 25.0f;
    return;
  if (partsym == "RTY")
    sc.BaseGraphScaleConstRange = 11.2f;
    sc.BaseGraphHorizontalGridLineIncrement = 5.0f;
    return;
This thing is very important for me.
As for individual Bid/Ask Minimum Volume Compare Threshold in Numbers Bars now it isn't important for me.
