Date/Time: Tue, 21 Jan 2025 23:54:24 +0000
Customize Chart/DOM Column dialog missing
View Count: 637
[2018-08-28 18:08:54]
jaxscott1 - Posts: 24
When calling up the Trade|Customize Chart/Trade DOM Column settings, no dialog appears and when attempting to interact with ANY part of the program produces a "bing" AS IF there is a dialog that needs to be "OK'd" or Cancelled before going further. So I can't "reset windows" or anything like that to get an errant dialog back under control. The only thing to do is ESCAPE key out and then control is back to normal. Bug?
Prelease version 1793
[2018-08-28 20:05:59]
It is an operating system bug.
Refer to:
High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.40 - Dialog Windows Do Not Display
