Date/Time: Tue, 21 Jan 2025 23:53:56 +0000
alarm!
View Count: 1476
[2018-08-28 17:27:53]
bercor - Posts: 30
Hello!
I have set several sound alarms when certain graphic conditions occur.
The alarms work but I do not report on the chart or even in the window dedicated what was the trigger. You can give me a hand and tell me how to make a trigger symbol appear on the chart or show the alarm window. Thanks so much
[2018-08-28 18:10:33]
First check to see that you see the alert message in Window >> Alert Manager >> Alerts.
[2018-08-28 18:27:10]
bercor - Posts: 30
Thanks for your reply but I wrote to you why in WINDOWS I can not find the ALERT MANAGER choice. ps I attach image! thank you so much
imagesierra+.png / V - Attached On 2018-08-28 18:26:57 UTC - Size: 21.77 KB - 282 views
[2018-08-28 18:40:30]
Select Window >> Reset Windows and then try opening the Alert Manager again with Window >> Show/Hide Alert Manager.
Date Time Of Last Edit: 2018-08-28 18:41:05
[2018-08-28 19:09:57]
bercor - Posts: 30
I'll explain. For example, I set a sound alarm when the MACD average cuts the MACD. is it possible to exit a symbol on the price chart when this event occurs, over the sound alarm? thank you
[2018-08-29 00:56:26]
Really for this would be best to use the Color Bar Based on Alert Condition study:
