Date/Time: Tue, 21 Jan 2025 23:57:18 +0000
[Programming Help] - HOWTO Remove ".00" At (CUSTOM VALUE AT Y ) ?
View Count: 892
[2018-08-28 11:13:10] |
User574685 - Posts: 28 |
Hi, is there an option to remove somehow zeros after decimal point at Custom Value At Y Subgraf ? Thanks Dave |
[2018-08-28 15:28:10] |
ForgivingComputers.com - Posts: 989 |
Change the Study's Value Format to 1.
[2018-08-29 00:52:42] |
Yes this is controlled through the Value Format for the study: Chart Studies: Settings and Inputs Tab >> Value Format Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
