Date/Time: Wed, 22 Jan 2025 00:02:08 +0000
XNJ.AX Historical data
View Count: 699
[2018-08-28 00:11:26] |
User629461 - Posts: 184 |
Hi, I notice the code XNJ.AX (ASX Industrial Sector) has limited historical data (only back to about 2014) compared to similar codes (eg XMJ.AX) which go back to at least 2005. Can you please advise, thanks |
[2018-08-28 00:39:36] |
Also, XIJ.AX (ASX IT Sector) has the same limited data.
[2018-08-28 18:37:07] |
Whatever data is available for those symbols cannot be changed. We cannot change what is available.
