Date/Time: Wed, 22 Jan 2025 00:01:22 +0000
Multiple Charts Visible
View Count: 1219
[2018-08-27 18:06:51] |
User94606 - Posts: 327 |
Is there a way to view multiple charts (1-min, 5-min, 4K tick) simultaneously? Currently, I have multiple charts in a charbook but I need to use F8 to go thru each chart
[2018-08-27 18:09:36] |
Yes. Refer to: Window, CB and CW Menus: Tile Horizontally (Window) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
