Date/Time: Wed, 22 Jan 2025 00:06:36 +0000
starting time on charts changed
View Count: 789
[2018-08-27 16:30:49]
User465776 - Posts: 2
Hi, I'm using the 1785 64bit version with the CQG data feed. I have a problem with my charts starting time. I have all my charts setup to New York time, so my CL for example, starts at 18:00 on sundays. The end time is at 17:00. The problem is this time it started at 20:00 and I haven't made any change in my charts. I don't know if the problem is with CQG or with you guys.
[2018-08-27 18:20:06]
First thing to do is to correct the Session Times in the Chart >> Chart Settings and then refer to this section here:
Global Symbol Settings: Setting of Intraday Chart Session Times
Date Time Of Last Edit: 2018-08-27 18:25:26
