Date/Time: Wed, 22 Jan 2025 00:09:47 +0000
MARKET PROFILE CHALLENGES
View Count: 634
[2018-08-27 07:25:57] |
User436940 - Posts: 23 |
I recently observed that the market profile is showing the initial balance based on 08.30Eastern time versus 09:30. The profile is one of the study set by Infinity futures. I sense it was set to use central time but the system is currently using Eastern time to process. Any idea of what will be required to address the problem? There is no reference to time in the graph settings.
[2018-08-27 08:55:35] |
You need to adjust the Session Times for the chart as required: Chart Session Times Also refer to: Time Price Opportunity (TPO) Profile Charts: TPO Letter Codes and Letter Customization Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
