Date/Time: Wed, 22 Jan 2025 00:11:45 +0000
Time Line study, another input
View Count: 697
[2018-08-27 05:50:02] |
User546829 - Posts: 5 |
Is there a way for the "Time Line" study to choose specific days to plot on. I use 1 instance of it to draw a vertical line for the start of trading everyday 9:30. Would like to create 1 for (just) Sundays, start of trading 12:00. thanks |
[2018-08-27 07:57:49] |
The study can be modified to accomplish this. Refer to this page for instructions: How to Build an Advanced Custom Study from Source Code The study is scsf_VerticalTimeLine in studies2.cpp. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
