Date/Time: Wed, 22 Jan 2025 04:22:46 +0000
cannot set Chart Data Output Specification Type to By Name
View Count: 621
[2018-08-27 01:01:23] |
rabbitTrader - Posts: 16 |
I'm using the Spreadsheet System for Trading. I'm able to change and save Chart Data Output Specification Type to By Name. But when I move down to the Chart Data Output Sheet Name text string, any name I give is immediately overridden and not saved. SC reverts to the Sheet# format. Please advise. Thanks. For reference: Sierra Chart version 1785 Spreadsheet Study Inputs: Chart Data Output Specification Type |
[2018-08-28 21:47:45] |
We are looking into this issue now.
[2018-09-05 08:19:49] |
Letting you know this has been resolved in the current release.
