Date/Time: Wed, 22 Jan 2025 00:12:07 +0000
TickSize for an 'external' chart symbol
View Count: 1025
[2018-08-24 23:06:06] |
User99735 - Posts: 234 |
Hi, Is there a ACSIL function available to fetch the TickSize for an 'external' chart symbol, using the chart number. If not, could you please add one? Regards Vivek |
[2018-08-25 01:07:36] |
Yes there is this function: double sc.GetSymbolDataValue(SymbolDataValuesEnum ValueToReturn, const SCString& SymbolForData = SCString(), bool SubscribeToMarketData = false, bool SubscribeToMarketDepth = false)
You will want to use this as the first parameter: SYMBOL_DATA_TICK_SIZE Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
