Date/Time: Tue, 21 Jan 2025 23:54:46 +0000
User Questions
View Count: 667
[2018-08-24 19:01:37] |
Sierra Chart - Max - Posts: 5779 |
Ok, so far I am very satisfied with your services.
So in summary the total monthly payments would be: $33 Sierra Pack 5 $25 Data Feed of SC (20 symbols) $3,25 Exchange Fee (Full CME nonpro) Total of $61,25 Monthly. Correct? Also. Can I see Footprints with the CME for non-prof data feed? Or do I need Full CME with Market Depth? Thing is I want the cheapest way to have footprints. (So far I have been seeing them with the Full CME nonpro) Last thing. How does the 20 real time symbols work with SC exchange data feed? How are the 20 “counted” or limited? Sierra Chart Support |
[2018-08-25 01:11:30] |
Total of $61,25 Monthly. Yes.Correct? Also. Can I see Footprints with the CME for non-prof data feed? Yes.Last thing. How does the 20 real time symbols work with SC exchange data feed? How are the 20 “counted” or limited? This is explained here:Chart Data and Chart Data Files: Reducing Number of Symbols Being Tracked by Sierra Chart Only those particular symbols which are coming from the Sierra Chart Exchange Data Feed will count towards the limit. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
