Date/Time: Sun, 24 Nov 2024 12:11:50 +0000
text size w/ Volume@price study
View Count: 1702
[2013-10-22 05:02:36] |
SKY - Posts: 45 |
can't find where in Sierrachart can I control the appearance of the text (volume numbers) displayed by the Volume@price study pls advise. tnx. p.s. in general I think it would be right to indicate in help content to indicate (for relevant studies) how to modify involved colors/text as there are few entries to control text in the global setting menu (in the Volume@price study case - none of them affected the appearance of the volume numbers) |
[2013-10-22 20:35:50] |
User14266 - Posts: 225 |
The setting you are looking for is not in the global setting. Simply go to the study settings for the VbP study you are using. Then, go to the "Subgraphs" tab. This is where you will find the graphic settings and text settings for the Volume text. The one you are looking for is "Volume Numbers Text Color and Size". You can change text to any size or color that you desire. Enjoy. |
[2013-10-22 20:38:15] |
By the way, each study has it's own settings.
[2013-10-25 03:06:53] |
The answer given in post #2 is correct and is documented here: https://www.sierrachart.com/index.php?l=doc/doc_VolumeByPrice.html#Color Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
