Date/Time: Wed, 27 Nov 2024 20:51:37 +0000
Remote Build
View Count: 1687
[2018-08-24 17:48:43]
infpz - Posts: 826
Possible to #include "scstudyfunctions.h" and "scstudyfunctions.cpp" in your Remote Build local directory for users to generate Custom Studies?
[2018-08-24 18:10:47]
We probably could but you can always just copy the particular functions out of those files that you need and just put them into your own source code CPP file. That is the procedure we have always recommended.
[2018-09-20 10:59:16]
User90125 - Posts: 715
Unfortunately, it looks like it SC still hasn't addressed the issue thru v1809 64-bit (24324:24325).
-- Starting remote build of Custom Studies Source files: CumulativeVolumeDeltaBars.cpp. 64-bit --
Allow time for the server to compile the files and build the DLL.
The remote build did not succeed. Result:
CumulativeVolumeDeltaBars.cpp:2:30: fatal error: scstudyfunctions.h: No such file or directory
compilation terminated.
-- End of Build --
For safety's sake, using built-in libraries that SC maintains should always ensure that custom code remains compliant with current and updated revisions.
[2018-09-20 14:15:20]
There is no issue here. First of all, there should be no reason to even be directly using SCStudyFunctions.cpp since all of those functions are accessible through ACSIL "sc." member functions. And you should not expect that the source code is even included during a Remote Build unless you include the code yourself in your source code file.
Date Time Of Last Edit: 2018-09-20 14:16:24
