Date/Time: Tue, 21 Jan 2025 23:52:46 +0000
Saving individual charts
View Count: 2096
[2018-08-24 17:36:29] |
User750920 - Posts: 280 |
Hi, I am new to SC and have started creating custom charts. I see how to save Chartbooks yet for some reason I cannot find (through search) or in the menu system how to save individual charts. And if I can rename upon saving the individual chart so that when I go to File>Open/New Intraday Chart it is there to be seen. Thanks |
[2018-08-24 18:31:53] |
There is not a way to save an individual chart. You can only save the entire active Chartbook and that is explained here: Chartbooks (Workspaces): To Save a Chartbook Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-08-24 18:50:38] |
Thanks... then why does it say file open/new (as if there is an option to open an existing chart). When I do that there is one chart there.. appears to be a default chart. But it looks like there could be more.
[2018-08-24 19:01:11] |
The File >> New/Open Historical/Intraday Chart commands are applying only to the chart data file itself. Not to any of the settings. You can use an existing chart as a template though for new charts. Refer to: Using Chart Templates Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-08-24 19:01:22
[2018-08-24 19:13:04] |
So I can create a template chart for say three different types of chart with differing settings? If so How do I save those templates so that when I go to File>Open/New historical/Intrady chart I will see them each. This is what I am confused about.
[2018-08-24 19:55:42] |
What you can do is duplicate any existing charts you have in a Chartbook by following the instructions here: Using Chart Templates: Duplicating Charts / Template Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-08-24 20:28:42] |
Thank you for the time and explanation.
