Date/Time: Wed, 22 Jan 2025 00:11:43 +0000
How can I remove the new version's blank bars.
View Count: 649
[2018-08-24 16:23:58] |
User414652 - Posts: 12 |
The new version has added blank bars between the the tabs and charts. What are they for and how can I remove them? Image attached. Version - 1785 Thanks! ~J Date Time Of Last Edit: 2018-08-24 16:24:42
18-08-24_10-12-24.png / V - Attached On 2018-08-24 16:15:20 UTC - Size: 1.72 MB - 345 views |
[2018-08-24 17:25:40] |
We have to look into this and see why that is happening.
