Date/Time: Wed, 22 Jan 2025 00:00:27 +0000
daily close positions
View Count: 626
[2018-08-24 15:44:55]
j_nathan - Posts: 22
Hello support
Is there any way to have my open positions auto close daily? Having issues not closing my positions and recall this option on another platform. Brielfy check the instructions but did not see. Will keep looking and any info appreciated.
Cheers
[2018-08-24 16:05:49]
Found it in the Global Profit / Loss Management settings
Last question is now that its enabled why does the status state:
"Loss management is disabled."
[2018-08-24 18:06:51]
This feature is documented here:
Global Profit/Loss Management
If you see "Loss management is disabled." it means it is not enabled for the selected account on the Global Profit/Loss Management window.
Here is the option that you have to enable for the loss management:
Global Profit/Loss Management: Daily Net Loss Management
Date Time Of Last Edit: 2018-08-24 18:08:15
[2018-08-24 21:01:10]
my apologies, confused loss management with flattening of positions
looks good now
