Date/Time: Tue, 21 Jan 2025 23:56:04 +0000
[User Discussion] - graphic display with method
View Count: 673
[2018-08-24 15:02:13] |
bercor - Posts: 30 |
I display the chart with the "Range Per Bar Standard (in ticks)" method as per attached file. The bricks are visualized and in the lower part there is the excel type reticle. I would like to remove this lower grid while keeping the brick display. You can give me a hand on how to remove this bottom grill. Thank you! |
mattoncini.PNG / V - Attached On 2018-08-24 14:54:05 UTC - Size: 14.13 KB - 268 views Attachment Deleted. mattoncini.PNG / V - Attached On 2018-08-24 14:54:43 UTC - Size: 14.13 KB - 257 views |
[2018-08-27 10:48:45] |
Can you give me a hand please? thank you Thanks. |
