Date/Time: Wed, 22 Jan 2025 00:14:09 +0000
DTC SubInstance of SC and SC market data
View Count: 631
[2018-08-24 11:22:50] |
User12089 - Posts: 364 |
For the same instrument on DTC Sub Instance of SC I am not getting the [M] indicator on the charts At the same time on the main instance of SC I do get the [M] indicator for the same instrument I have SC real-time and historical data subscription and use Interactive Brokers for/as a trading/execution service why am I not getting the [M] on charts on DTC Sub Instance of SC and does that mean? e.g. not receiving high quality SC historical and real-time data there? |
[2018-08-24 17:28:46] |
In a sub instance you will not see the [M] indicator but it is going to be the same data you have in the main instance. It could not be any different. So if it is real time in the main instance, it will not be real-time in the sub instance as well.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-08-24 17:29:11
