Date/Time: Tue, 21 Jan 2025 23:59:23 +0000
Placement of bar end timer
View Count: 687
[2018-08-23 20:32:27] |
User101663 - Posts: 1 |
I'm considering moving over to Sierra Charts from Ninjatrader. I haven't been able to locate where the Sierra bar end timer is located on a chart. Is it possible to move or create custom bar end timer so that it shows at the bottom right of chart as shown in the chart ex.(see attachment) Ive included?... or just below the present price scale(like the yellow highlighted present price on chart example.
M6A 09-18 (60 Min) 8_23_2018.jpg / V - Attached On 2018-08-23 20:30:40 UTC - Size: 82.74 KB - 308 views Attachment Deleted. |
[2018-08-23 20:36:52] |
Refer to the Countdown Timer study: Countdown Timer Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
