Date/Time: Tue, 21 Jan 2025 12:20:30 +0000
Blacked out menu boxes
View Count: 600
[2018-08-23 15:51:01]
User472538 - Posts: 3
Hi support.. All my menu boxes (for example "allow support for sierra chart data feeds") are completely blacked out. They checking/unchecking of boxes work, for example I can reveal my passwords, or not. In the case of the above "allow support" setting, I can't tell if it's turned on or not. I set the Global settings/Global graphic settings to default, no joy. Same with "customize menu items", set those to default. Searched support, googled it. No joy. Sorry to ask.
[2018-08-23 16:40:07]
Close unneeded programs you are running on your computer and restart Sierra Chart.
If that does not help, then restart your computer.
This is going to be an operating system resource issue.
Date Time Of Last Edit: 2018-08-23 16:40:30
