Date/Time: Tue, 04 Nov 2025 17:22:13 +0000
Crude Oil Charts not updating on CQG data
View Count: 1825
[2018-08-23 09:45:13]
User275371 - Posts: 5
Anybody having issues with Crude Oil (October 2018) contract data not updating?
https://gyazo.com/1d7beb2cc3e3168a67819eaa841febab
stops working after message log connects... running on CQG data thru AMP futures.
Thanks in Advance.
[2018-08-23 11:23:55]
ktfroy - Posts: 85
UPDATE - Now not running - Message: Symbol unknown.
Data ran briefly for about 10 mins stopping at 07:29:11 EDT
Date Time Of Last Edit: 2018-08-23 11:35:24
[2018-08-23 12:14:25]
ktfroy - Posts: 85
Amp and CQG notified - both suggest issue could be with Sierra. Waiting .... will they respond please
[2018-08-23 12:37:13]
Yup... chart is frozen... and running CQG via AMP
The CQG runs fine on NinjaTrader 8 (Go Figure)
https://gyazo.com/ce9b64bfe7296c6fd0799f8ae7ccf2e6
https://gyazo.com/7ec7c36bb24428c776653b033e17c985
[2018-08-23 12:58:06]
User996274 - Posts: 96
runs fine on IB as well
[2018-08-23 13:15:51]
nioko54130 - Posts: 108
Hi dear SC support
i have met the same problem on the FDAX since yesterday for two of my colleague with CQG
[2018-08-23 13:18:44]
User155555 - Posts: 15
Same here w/ CQG. CLEV18 runs for couple min then froze w/ message symbol unknown. Disconnect then reconnect it fixed for couple minutes then again.
Date Time Of Last Edit: 2018-08-23 13:26:22
[2018-08-23 13:42:06]
User886711 - Posts: 5
Yes, I have the same problem. ES updating fine but CLEV18 keeps cutting out.
[2018-08-23 13:45:22]
j_nathan - Posts: 22
ditto and please address, this is my job :D
[2018-08-23 14:04:16]
honestly its the weirdest problem ever, turned off windows firewall, rebooted X times
other tickers update for CL like CLEX18, CLEZ18 but CLEV18 starts then stops like the feed times out
emailed my ISP also to make sure no routing issues but likely not with other tickers updating
so more like a WTF with CQG and CLEV , hope it gets fixed soon, CLEV could really drop and hate to miss the action
[2018-08-23 16:38:21]
This must be a CQG issue. It is not possible to be a Sierra Chart issue.
[2018-08-24 15:55:55]
unfortunately it was bad timing, when opening platforms in sequence it came across as Sierra with the degradation
coming to the board and seeing other just the same
thank you for the prompt replies, cqg cleared it up afterwards whatever it was
