Date/Time: Tue, 21 Jan 2025 12:20:46 +0000
pullback column`
View Count: 1090
[2018-08-23 05:57:17] |
User99934 - Posts: 227 |
There are many times I would like indicators to access the pullback column. Would you consider making this available?
[2018-08-23 06:14:04] |
This is available through ACSIL: sc.PullbackVolumeAtPrice. And Simple Alert Formulas can reference the data as well. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
