Date/Time: Wed, 22 Jan 2025 00:11:19 +0000
Restrictions of a strategy to work with previous order
View Count: 778
[2018-08-23 04:50:02] |
User271989 - Posts: 44 |
Let's say I have a strategy wich send multiple orders and send a take profit order for each position. If a have a a problem with my pc and needs to start again there is anything that makes impossible to this strategy to verify all previous orders/positions and works properly? For example will I aways needs to flatten my previous positions or clear manually anything to start with the strategy again? Or a coder should be able to make the strategy deal with it automatically? |
[2018-08-23 15:54:07] |
ì mean: the language/software allows the dev to make the strategy in a way the user doen`t needes any human intervention to start to work properly?
[2018-08-23 17:07:09] |
Yes certainly a programmer using the ACSIL trading functionality can accomplish all of this. Refer to: Automated Trading From an Advanced Custom Study And refer to: Automated Trading Management: Automatic Recovery of Trading System After Restart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
