Date/Time: Tue, 21 Jan 2025 12:19:34 +0000
persistent variables are not re-initialized on chart recalculation
View Count: 654
[2018-08-22 23:21:18] |
Andy Sureway - Posts: 93 |
Persistent variable are initialized to zero when the analysis is first added. However, when we do chart recalculate, these variables still keep the memories of their past lives.
[2018-08-22 23:43:36] |
Yes that is correct and is documented.
