Date/Time: Tue, 21 Jan 2025 12:23:40 +0000
CFD's just broke for 5 minutes
View Count: 670
[2018-08-22 18:12:28] |
Cyberdogk9 - Posts: 27 |
Hi 10 minutes ago there was some bug and quotes stopped for 5 minutes then go on but with wrong prices, for example spx500. Can you please fix it? |
[2018-08-22 18:30:46] |
Yes we do see that interruption. There is nothing to fix. It was an issue with the FXCM data feed. The prices are not wrong. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-08-22 18:30:55
