Date/Time: Tue, 21 Jan 2025 12:28:39 +0000
safe mode enabled
View Count: 1419
[2018-08-22 18:09:16] |
Tomas21 - Posts: 23 |
I can't chart my custom studies ( which were working before) , now get custom study ( safe mode enabled) I hadn't changed anything , and of course can't use it now?
[2018-08-22 18:12:30] |
Disable Safe Mode. Here is the documentation for that: Sierra Chart - Software Login Instructions: Using Safe Mode Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
