Date/Time: Tue, 21 Jan 2025 12:22:56 +0000
Request - Cumulative Up and Down Volume
View Count: 875
[2018-08-22 13:51:55] |
User360283 - Posts: 506 |
The study Cumulative Volume does not indicate up versus down volume. OK as is but it would be very useful to have a study that plots Cumulative Up and Down Volume as a ribbon (like fill top and fill bottom). Thanks |
[2018-08-22 18:15:08] |
Have a look at the Cumulative Delta Bars-Volume study: Cumulative Delta Bars - Volume Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-08-23 09:29:43] |
Thanks for the info about the Cumulative Delta Volume. I tried it but it's not quite I had in mind since I can't get the bars to be tall enough in the 4th section of my chart and the Draw styles are limited to only Visible or Ignore. I still would like to see this data in a ribbon. Thanks again |
