Date/Time: Sun, 24 Nov 2024 10:36:39 +0000
User Email Questions - OCO with IB
View Count: 1536
[2013-10-21 21:16:26] |
Sierra Chart - Max - Posts: 5730 |
Setup fine. NO Problem. Just started the Trial. Having problem with OCO order. Spent hours...no resolution. The only order I need: Forex: Initial 30 pip stop...with 30 pip initial target, then stop raised to breakeven on remainder with second target 60 pips and third target 90 pips. There is something I am not doing correctly, tried stop:stop and also Group1, Group2, Group3. Can you help me? Can't find a solution with youtube videos and the forum posts. Thanks, If I can get this working, I will use it with IB. Sierra Chart Support |
[2013-10-22 08:35:37] |
tobi - Posts: 351 |
The attached twconfig file should do what you're looking for: Initial stop: 30 pips Target 1: 30 pips Target 2: 60 pips Target 3: 90 pips When Target 1 is reached/filled the stop is moved to entry. Copy the attached twconfig file in SC's data folder and choose it in the Trading DOM. With this twconfig file be aware of: - using 2 decimals in Price Display Format and Tick Size for JPY pairs - using 4 decimals in Price Display Format and Tick Size for none JPY pairs In case you're using 3 respectively 5 decimals, you have to double the stop (60) and targets (60, 120, 180) as these are ticks. The choosen position size is 300000 with each target scaling out 1/3 (100000). You might want to adjust that to your personal needs. |
30.30-60-90.twconfig - Attached On 2013-10-22 08:35:32 UTC - Size: 6.18 KB - 554 views |
[2013-10-23 03:43:38] |
Thank you for this. To use the attached Trade Window Configuration file provided by the user, follow the instructions here: http://www.sierrachart.com/index.php?l=doc/doc_TradeWindow.html#ConfigurationFileAnotherSource Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-10-23 03:43:55
