Date/Time: Tue, 21 Jan 2025 23:58:19 +0000
Changing brokers
View Count: 656
[2018-08-22 01:39:53] |
User560075 - Posts: 10 |
Hi, I am currently with AMP Futures and will be changing over to Infinity/Transact. I have an install/enablement through AMP for SC of course. I would like to keep this installation as I have two indicator licences tied to my Sierra Chart Account number. Setting those up again would be a pain. My question is can I keep my current installation of SC with the associated AC number, and be enabled for this installation via Infitiny/Transact? This I would imagine would save me asking two indicator vendors to set me up again. Trust this makes sense. I have not done this before. Thank you. Patrick |
[2018-08-22 06:17:30] |
You can certainly keep the same installation but you are going to require your own direct account to use with it. This is explained here: Direct Sierra Chart Account I would like to keep this installation as I have two indicator licences tied to my Sierra Chart Account number. Here are the Transact Setup Instructions: https://www.sierrachart.com/index.php?page=doc/TransAct.php#SetupInstructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-08-22 06:17:53
[2018-08-23 11:46:53] |
Thanks your response. As an alternative, the Infinity instance of SC is subsidized. Therefore I would be better off installing their version, and closing my account with AMP. I would need to reinstall or copy indicators to a new data folder. Is this correct? and if so, would I still retain the same SC account number I have now? Thanks and regards, Patrick |
[2018-08-23 17:18:12] |
. I would need to reinstall or copy indicators to a new data folder. Is this correct? Yes.and if so, would I still retain the same SC account number I have now? You will have a different Sierra Chart Account Name.
