Date/Time: Wed, 22 Jan 2025 23:08:44 +0000
change chart period
View Count: 1155
[2018-08-21 21:15:40] |
tomtom - Posts: 53 |
Hello, Is it possible to install in - chart settings - historical chart bar period - as in days also weekly and monthly to change the period thanks |
[2018-08-21 21:35:37] |
We are not really understanding this since those settings already exist in Chart >> Chart Settings for historical charts. Did you want to programmatically change the bar period through ACSIL? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-08-21 21:35:50
[2018-08-21 21:58:21] |
I know that exist but only for days , for example i like to see chart period as a 2 weekly candle or 4 monthly or half year candle
[2018-08-21 22:02:50] |
like this for weekly and monthly [img]https://up.picr.de/33627014zn.jpg[/img] Date Time Of Last Edit: 2018-08-21 22:22:50
[2018-10-28 23:18:49] |
PPlease make available setting changing chart period for week and month
[2018-10-30 04:57:32] |
Do you mean programmatically? Or do you mean to be able to specify the number of weeks and months?
[2018-10-30 18:52:50] |
So that I can select weeks or months as in days For example, I would like to have a candle displayed for 2 weeks 4 months and 6 months |
