Date/Time: Tue, 21 Jan 2025 12:17:32 +0000
Price Spacing When Changing to a Different Symbol
View Count: 678
[2018-08-21 15:11:46]
tdd2672 - Posts: 61
I utilize the quote board to quickly change symbols on my primary chartbook. When I change from NQ to RTY the price scale will compress and it'll expand going back to NQ. This applies to other symbols as well. Is there a way to keep the tick (price) spacing constant when switching between charts with 1/4 tick and 1/10 increments, etc.? I want to avoid having to manually adjusting the scale each time.
[2018-08-21 19:50:44]
As long as the chart bars are fully within view within the chart window when changing the symbol, it does not sound as though there is anything we can help with here.
[2018-08-23 15:25:12]
tdd2672 - Posts: 61
I keep this particular chart on constant range. If you could implement a setting to adjust the scale range by pixels in addition to the current setting options it would likely solve the issue.
