Date/Time: Tue, 21 Jan 2025 10:40:30 +0000
remove unwanted custom indicators
View Count: 850
[2018-08-21 11:00:11]
Trader&Hunter - Posts: 131
CAn i remove some unwanted indicators. things I don't use. I tried to delete from data folder but it always re appears.
[2018-08-21 17:51:55]
It sounds like you have a Custom Study that is being automatically downloaded to your computer. You can disable the option for these automatic downloads on this page:
https://www.sierrachart.com/UserControlPanel.php?page=EnabledCustomStudies
The option is at the top under the heading Toggle File Download. Select the button for Disable File Downloads to stop the automatic download.
